The shift rod adjustment sounds complicated in the manual, but is actually simple: Shift into a gear, then screw the rod in or out until the detent ball is evenly bottomed in its slot. When correctly adjusted, the fork will be centered evenly in its ring, with no pressure to move either forward or backward. |
